9-4X Leedus
Postitatud: K Jaan 05, 2022 14:08
Postitas cupsave
Re: 9-4X Leedus
Postitatud: L Jaan 15, 2022 13:22
Postitas Zazou
Oleks sellega ettevaatlik, kui kunagi uurisin selle kohta täpseamlt, sain müüjalt sellised kommentaarid:
Hello. The car is still available. It's from USA but it has Lithuanian registration. It was damaged in front end before. The car needs to be repainted and there are some oil leaks under the engine.
I can send you pictures a bit later, but the whole body needs to be repainted.
The car doesn't have keyless entry and start from remote control
Engine and gearbox have oil leaks, the car needs to be repaired.
