Pult jamab, palun abi.
Postitatud: E Nov 19, 2018 19:10
Postitas annakas77
Nii, olen nüüd vahelüli asjapulkade ja mu auto uue omaniku vahel. Puldiga oli ka mul probleeme ja lukustus ja avamine ei töötanud nii nagu peaks ja mõnikord seisin pulti klõpsides mitu minutit auto kõrval, lõpuks loobusin ja tegin võtmega uksed lahti. Panin ka uue patarei aga ei misit. Ja sidil pidevalt kiri, et remote battery jama. Täna sain siis omanikult kirja ja see saaga jätkub - äkki oskab keegi nõu anda.
Panin ka ta kirja siia:
Hi! Sorry for bothering you but I have an issue with the remote key and I really hope you can help me out.
I got a message that remote key battery was dead so obviously I replaced it. From then on the key is totally dead and even though I installed another battery (maybe the first one was not good I thought) it still won't work and I am obliged to unlock and lock all doors manually all the time which is really annoying.
I have tried to re-sync keeping the key in the ignition and pushing any button for 5 seconds but it still does not work and I keep getting the same battery empty message every single time I switch the car on.
Any fix?
Re: Pult jamab, palun abi.
Postitatud: E Nov 19, 2018 19:51
Postitas qdwin
Mis auto?
Postitatud: T Nov 20, 2018 13:48
Postitas annakas77
Vabandust, jäi lisamata: 9-3 2004
