M: Autovõimendi JBL GTO 755.6 II
LPT
Auto: Tonnine, OG9-5
L Juun 16, 2018 7:50
Müüa 6-kanaliga autovõimendi JBL GTO 755.6 II, kaasa toitekondensaator Dietz 1,0 Farad 2,1 VDC Nr. 21204, toitekaablid ja 1 RCA. Ostsin eBayst 9-5-le, aga kuna kindalaeka alla ei mahu, siis pagasiruumi ei hakka reostama.
-6-channel car amplifier
-60 watts RMS x 4 + 107 watts RMS x 2 at 4 ohms (80 watts RMS x 4 + 150 watts RMS x 2 at 2 ohms)
-160 watts RMS x 2 + 300 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
-optional internal neon lighting (accommodates Street Glow AN9 tubes or equivalent, tubes not included)
-variable high- and low-pass filters on channels 1-4, low-pass only on sub channels (32-320 Hz, 12 dB per octave)
-bass boost on sub channels (0-12 dB)
-MOSFET power supply
-speaker- and preamp-level inputs
-preamp outputs
-CEA-2006 compliant
-fuse rating: 30A x 24-gauge power and ground leads recommended
-19-7/8"W x 2-3/8"H x 12-3/8"D
https://www.manualslib.com/manual/70543 ... 755.6%20II
Hinnaks küsiks 120.-, sama palju kui ta mul koos saatmisega Inglismaalt maksis. U2U
