Uus Saab 9-3
Skybound
Arildi blogis on tehtud päris hea kokkuvõte sellest, mida praeguseks hetkeks uuest 9-3 teada on. Mõned lõigud sellest postist:
[quote]
/.../ The modular architecture Saab developed consists of several modules or parts with fixed interfaces. If they need to redesign the architecture to fit a future vehicle or to implement new technology, instead of redesigning the whole architecture they can just redesign the affected modules. In other words, it's both cost effective and time effective.
One big advantage of developing the in house platform is that this platform is only developed with Saab in mind, and thus both the chassis and the drive line will be more than 100 kg lighter than the Delta II platform. In addition, Saab has worked hard on reducing the front overhang and moving the front wheel forward. This should give better handling, but also a more flexible engine bay which will make it easier to adapt to different engines suppliers. /.../
/.../ The front suspension will be a unique McPherson design, with aluminum lower A-arms. In the rear the suspension will be a 5-link independent design, which will be used on all future Saabs. This solution will give excellent set up possibilities and is also very light and stiff. This should give the car excellent handling. /.../
/.../ The one engine we know about at the time being is the four cylinder 1.6 liter petrol engine sourced from BMW. This is a compact aluminum head/block engine with cast iron liners. It has a double overhead chain-driven camshaft, four valves per cylinder with variable valve timing (inlet and outlet) and variable valve lift (inlet). Furthermore, direct Injection, intercooled twin scroll turbocharger and Bosch electronic engine management. It has Stop/start functionality and regenerative braking during fuel cut-off. In other words, a very advanced engine, which actually was recently awarded engine of the year. /.../
/.../ In the rear the next 9-3 will use Saab's in house developed electric rear axle. This will give the car four wheel drive with the internal combustion engine driving the front wheels and the electric motor driving the rear wheels. The electric motor will source its power from an air cooled 1.1 kW/h lithium ion battery pack, which will be charged through regenerative braking. The rear axle will provide the car with electric power boost, torque vectoring and traction support.
The great thing about the eXWD system is that it will not just give the car four wheel drive without fuel penalty – as the rear wheels are driven by regenerated energy from braking – it will actually reduce fuel consumption and CO2 emission up to 30 percent as the rear motor will take some strain off the internal combustion engine. The system is most fuel efficient in urban driving and low speeds when the car can go more or less just on electric power. In higher speeds the systems next big advantage is evident when torque vectoring gives excellent handling and grip through curves. Mangnus Rydell, sales manager at e-AAM, says that the system has a two year lead on the competitors.
Best of all about the eXWD system, unlike most hybrid systems, it is very affordable. A Saab with the eXWD drive will not cost more than a current XWD Saab.
So the eXWD system fits perfectly into Saab's vision of responsible performance, i.e. to reduce consumption and emission, but without compromising handling or the enjoyment of driving. /.../
/.../ In the next 9-3 Saab will debut a all new infotainment system named IQon. This system is built on Google's Android OS. In addition to controlling multimedia and car functions, the IQon system will let users download a wide range of applications, online services and multi-media functions provided through a Saab IQon store. And thus keep the system updated during the whole life of the car. /.../
/.../ The front of the next 9-3 will be close to the PhoeniX concept shown at the Geneva Motor Show in March this year. The head lamps will though be slightly bigger, but the body painted wing in the grille will continue into the headlights just like on the concept car. The shape of the bonnet will also be close to the concept, but the front fenders will be bigger and more pronounced, giving the car a more masculine expression. And the windshield will of course be wrapped around the driver. The roof line will be descending sharper than on the concept and the rear will be lower. The rear will have a horizontal tail light arrangement.
One of those who have seen the real car commented that "it had a Porsche-like rear with a fin". Another lucky observer said that "the car was a five door hatchback. It looked like a true Saab, modern, but the look of the 900 prior to the GM 900". A third observer said that "it will be a hatchback, a return to the Saab tradition. Compared with today's 9-3, the waistline is higher, the rear window descends less and the rear is quite high." /.../
/.../ It has been confirmed that the car will be available in three main variant; as a hatchback, a crossover and a convertible. /.../
IQ*
Komakonstaabel
IQon. Nu-nuh...
SAAB on tegusõna!
foxer
IQon Store ja muud Android vidinad... kõlab, et varsti võetakse ka meie autod pahalaste poolt kübermeetmetega üle :)
Mere
Huvitav milliseks ta hinnaklass kujuneb..
aednik
Auto: Diisel Saab
#30
Kere tagaosa on super, esiosa tänu laugele esiklaasile täitsa mõttetu, kui on selline nagu pildil.
Elektriline tagasild on vägev leiutis, aga kahtlane, kas see ainult pidurdamisenergiast suudab silla-aku ära laadida.
NO FEAR
Säärane Mulk
Auto: päris mitu...
#31
Huvitav, millest kirjutatakse ka...
anthillse
Oli soov kunagi uue Saab 9-3 juurde tagasi tulla aga oma luukpära Porche koopiaga rikuvad ilusa asja ära :wall:
Oleks vaja ikka tuleviku suunas liikuda mitte minevikus olla :gun:
Kahju
aednik
Auto: Diisel Saab
#33
Saba võiks pikem olla, nagu hüääni saba.
Jälle tuleb mainida, et porilapatsid on puudu.
ivark
Sellise ostaks küll, põnevust jätkub.
IQ*
Komakonstaabel
Võibolla olen ma imelik, aga mulle tunduvad kaks ülemist pilti kahtlaselt sarnased. Kerekuju poolest. Samas on see karvane udupilt äratuntavalt saabilik. Loodetavasti ei ole hiinlastel plaanis greifi uue vapilooma vastu vahetada.
Üks Porsche pilt ka lisaks.
SAAB on tegusõna!
eston21
Auto: 9-3ss aero
#37
see mazda6 tagatiib mulle küll ei istu.
dreamer12
Auto: Saab 9000 Aero 2,3T MY96; Saab 9-5 Aero Hirsch TTiD MY11
Pildi lekitas Svenska Dagbladet - olevat pärit saneerimise dokumentidega kaasas olnud Powerpint esitluse koopiast. Sellest ka artikkel Rootsi keeles siin (artikli juures ka pilt + pilt, mis aastal, mis mudel kavas): http://www.svd.se/naringsliv/motor/har- ... 596872.svd
Pildi õigsus on leidnud ka kaudset kinnitust: http://inside.saab.com/poll-leaked-saab-image/
Uus Saab 9-3 tuginevat esiosa poolest Saab Phoenixile. Jason Castriota on ka välja toonud, et uus Saab 9-3 saab olema 150 millimeetrit lühema telgede vahega ja ca 4,4 m pikk.
Tänastes uudistes on välja toodud ka see, et Hiina tööstusminiseter Miao Wei põhimõtteliselt toetab Saabi ostu hiinlaste poolt. Seega võibolla hakkab uus Saab 9-3 teedel vurama 2013 aastal nagu äriplaan ette näeb!
http://www.headandlead.com - visioonid, planeeringud & ettevõtluskonsultatsioonid
spark
anthillse
:D See on nagu uus 9-5 aga keskelt on 1m jupp lihtsalt välja lõikatud :P
Aga loodame et tuleb ikka sedaan mitte luukpära nagu fotol näha on :(
ebuprofen
beebi 9-5 :D
Gals
See tagumine uks ei sobi sinna apppsoluutselt. Kupeena oleks ta samas päris kobe isegi.
tõh
Auto: Saabitu
#43
Aga palun:
Samas:
People that know how the final car looks like have said that the blurry picture of last week was a pre JC design, and thus not really the real deal.
Gals
See juba läheb.:)
Kuigi päris Porchelik on ta tõesti. Aga mis isiklikult ei meeldi veel, on see kapoti osa, mis on jube lühike ja jätab seetõttu häbelikku omapära. Pigem võiks esiklaas järsemalt alla minna ja sellevõrra ka auto nina pikem ja esiletoodum olla.
Aga eks elame ja näeme millal see real deal üldse alguse saab.
uralavto
Teljevahe on minu jaoks häirivalt väike :)
que
Auto: GMmees
#46
oleksin just ise luukpära poolt.. parem ju asju transportida.. üks saab 9-3ssi miinuseid minu arvates
vallikas
Kena, aga need tõllarattad torkavad kaks silma peast välja, natu väiksemad veljed ja rohkem kummi oleks tasakaalukam vaadata.
heikiw
Uue 9-3 loomisel võiks olla lähtepunktiks Klassik Aero. Jason Castriota loomingust: Lancia Stratos- pole mu meelest paha tulemus?!Ja mu meelest ei pea minema selle disainiga niikaugele, et enam ei saa aru, kas ikka on veel tegu autoga:D
Saab kasutada lihtsalt uusi tehnoloogiaid ja materjale, aga säilitada see "miski", mis meid selle margi juures hoiab.Aga paraku autotootmine on äri ja raamatupidajad panevad disaineritele ja inseneridele päitsed pähe kahjuks.Isiklikult loodan, et uus 9-3 ei oleks suurema venna kloon, vaid oleks ikka kõvasti erinev :)
margusmaa
Pildipealt näeb see 9 - 3 küll vihane välja. Rattad võiks võibolla natuke väiksemad olla sest tunduvad kuidagi mega suured.
welts
See 9-3 Hatchback näeb küll edev välja, muidugi kui sel on samasugune tagumine osa nagu on universaalkerega 9-3 siis rikuks kõik ilusa ära.
Sedaan kerega variant on ka päris ilus, kuigi võiks veidi saledam välja näha, liiga suured veljed samuti kaotaks ära.
