Race.Fi from Finland introducing
Homunkulus
Race.fi customer service gets from me 11 points out of 10! Ordered a wrong part, which in all honesty was partly my own fault as I didn't double-check the codes, and it took me exactly 1 e-mail to clear the situation. New part was sent out even before they had the "old" one back. No extra charges, no mistrust, just quick and correct service. Even included some lakritsi with the second parcel
Very-very pleased with your company!
Davies Craig electric water pumps -10 % on weekly
Polar bears have finally disappeared from the Helsinki streets, so we're pretty sure summer has finally arrived. Lets put the Davies Craig electric water pumps on promo this time!
An electric water pump can be installed as a booster in-line with the original pump, or more commonly as a full replacement by either removing the belt & emptying the original pump or installing a block-off plate.
The definite benefit of an electric pump is it's set rate of flow, meaning the pumped amount is just correct from idle rpm to redline conditions. A traditional pump will spin way more than needed in cars which frequently see high rpm's.
A separate controller is also available. The controller has a temp sensor and runs the pump at the needed speeds ensuring a quick reach to operating temperatures and avoiding so-called overcooling.
Checkout the DC pumps here:
»» Davies Craig electric water pumps
»» All cooling parts in our webshop
Have a great weekend! Race.Fi / Wille
This topic on our site
Weekie on Brisk and NGK -10 %
Even the latest summer cars should now be on the road, and in case testing reveals sputtering, here's some medicine to cure problems at least as far as plugs are concerned.
On the traditional weekie are Brisk and NGS plugs. All plugs are also plentiful in our own stock. The product descriptions offer more details than this topic including a cross reference chart of heat ratings.
NGK plugs are often told to be the one and only working plug especially in some turbocharged jap models. Why not, they're good plugs =)
From Brisk there are several models which are listed in the shop:
DS / Turbo -models: Especially for E85 and high boost pressure builds where no other plugs simply work.
LGS quad tip models: For cars with direct ignition plugs. Produces a good and long spark so these are also the most economical version.
Iridium -models: A traditional Iridium plug which can handle high temperatures are pressures. Easier on the coils and also suitable for mild E85 builds.
Silver: Competition engines and for hard to ignite fuels.
VAG -models have their own plug range.
»» Brisk Iridium plugs
»» Brisk LGS quad tip plugs
»» Brisk Silver plugs
»» Brisk DS plugs
»» Brisk VAG plugs
»» NGK Iridium plugs 6 - 9 heat range
This topic on our website
»» Brisk DS plugs
»» Brisk VAG plugs
Weekie: Luisi steering wheels and hubs -10 %
Luisi's steering wheels and bolt-on hubs have earned their permanent place in our range.
Luisi has made steering wheels and hubs since 1965. There's a hub and wheel for every car!
You can find the basic model hubs in the webshop, and can get the airbag models (not street legal) from sales as they are much less sold. There's suede and pu wheels, and hundreds of bolt-on hubs at great prices, so check them out in the shop.
Steering wheel hubs have a double pcd which includes most common steering wheel brands (6x70 & 6x74mm).
For example: FK, JOM, Tuning Line, Sparco, Momo, OMP and naturally Luisi steering wheels will bolt straight on.
Check out the Luisi range from our webshop:
»» Luisi steering wheel hubs
»» Luisi steering wheels
Other things from this week
Brisk & NGK spark plugs for every purpose!
»» Brisk and NGK sparkplugs
D2 coilovers: value for money. The best coilover kit in the price range for every car.
»» D2 coilovers: Value for money
Cometic gaskets and arp bolts are the choice when building any engine.
»» Cometic & ARP
High quality turbosmart boost controllers and blow off valves work accurately in all circumstances.
»» Turbosmart bleeds and BOV
-Riku
»» Cometic & ARP
-Riku
