M: VGate ELM 327 bluetooth autodiagnostika seade 12.- eur
Postitatud: T Mai 13, 2014 21:21
Saabus uus väike partii VGate ELM 327 diagnostikaseadmeid müüki.
Sobivad kõikidele autodele alates aastast 1996, millel olemas OBD2 standardile vastav diagnostikapesa.
Tarkvara versioon 1.5, seade töötab lisaks uusimatele ka kõige vanemate Android versioonidega.
Omadused:
Features:
1. CLEAR engine codes and check engine lights
2. Connect to an Android Smartphone using one of the many free compatible apps or a Bluetooth enabled computer using the supplied software
3. View real-time vehicle data while driving:
Engine RPM
Coolant Temperature
Calculated Load Value
Fuel System Status
KPH Speed
Short Term Fuel Trim
Long Term Fuel Trim
Intake Manifold Pressure
Timing Advance
Intake Air Temperature
Air Flow Rate
Absolute Throttle Position
Oxygen Sensor Voltages/Associated Short Term Fuel Trims
Fuel System Status
Fuel Pressure
4. Find and fix problems before they happen
5. Pays for itself with one use
6. Connects wireless via Bluetooth up to 3 meters (no cable connection)
7. Compatible with all OBD II compliant vehicles
Bluetooth Pairing Password: 1234
Latest Multi-Protocol Support:
SAE J1850 PWM (41.6 kbaud)
SAE J1850 VPW (10.4 kbaud)
ISO 9141-2 (5 baud init, 10.4 kbaud)
ISO 14230-4 KWP (5 baud init, 10.4 kbaud)
ISO 14230-4 KWP (fast init, 10.4 kbaud)
ISO 15765-4 CAN (11 bit ID, 500 kbaud)
ISO 15765-4 CAN (29 bit ID, 500 kbaud)
ISO 15765-4 CAN (11 bit ID, 250 kbaud)
ISO 15765-4 CAN (29 bit ID, 250 kbaud)
SAE J1939
Vehicle Coverage:
Works on all OBD II Vehicles (1996+ in USA and some 1994-1995) and EOBD vehicles (Petrol cars from 2001+ and diesel cars from 2003/2004 in Europe)
For your vehicle to be OBD II compliant it must have a 16-pin DLC (Data Link Connector) under the dash and the Vehicle Emission Control Information label must state that the vehicle is OBD II compliant.
Komplektis seade ja CD tarkvaradega.
Hind 12- eur. Asub Tartus, saan saata üle Eesti ka Post 24 automaati (saatmiskulu 2 eur juurde) ja Smartposti (saatmiskulu 3 eur juurde) Korra nädalas käin keskmiselt ka Tallinnas, lähimast ajast juhtub see neljapäeval 15. mail.
Kontakttel. 51 961 080
Omadused:
Features:
Engine RPM
Coolant Temperature
Fuel System Status
KPH Speed
Long Term Fuel Trim
Timing Advance
Air Flow Rate
Fuel System Status
Fuel Pressure
SAE J1939
Vehicle Coverage:
