#332;hulugeja küsimus !
Postitatud: L Jaan 31, 2015 19:01
Postitas arne20
Palju nende näitude tulemus peaks olema ? Kohapeal 34mg/s ja maanteel gaasipedaali kōvasti vajutades sai tulemuseks 108mg/s
Postitatud: L Jaan 31, 2015 23:39
Postitas Pootsman
Google räägib
* A wide open throttle (WOT) acceleration from a stop should cause the MAF sensor g/s display on the scan tool to increase rapidly. This increase should be from 6-12 g/s at idle to 230 g/s or more at the time of the 1-2 shift. If the increase is not observed, inspect for a restriction in the induction system or the exhaust system.
Postitatud: P Veebr 01, 2015 1:15
Postitas arne20
Suured tänud pootsman
