M: Alpine MRV-F545 võimendi
Makid, kõlarid, võimud...
inx
Lingil on sama toode info.
Müüdav toode pole uus, kuid sama hea kui uus :D
Kaablid annan ka kaasa kui on soovi.
Hind 250.-
Või vahetada alates 17" velgede vastu.
http://www.sonicelectronix.com/item_432 ... -F545.html
V12 High Power Amplifier
RMS Power Rating:
125 watts x 4 chan. @ 4 ohms
250 watts x 2 chan. (Ch 3-4 Only) @ 2 ohms
500 watts x 1 chan. (Ch 3-4 Only) @ 4 ohms Bridged
Blue LCD display: Shows off your system voltage, current, temperature, etc. for a killer install!
Detachable top cover to reveal the controls
Digital Information Center
Thermal Managment Processor
Amplifier Link: Connect to any compatible Alpine head unit for total control of your system.
Bass Engine:
Variable 30 - 400 Hz / 600 Hz - 8 kHz High- or Low-Pass Crossover
+16dB Bass Boost @ 45 Hz for Chan 3&4
MOSFET Power Supply: Gives clean clear sound
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
STAR Circuitry
Solid Copper Bus Bars
Auto Over-Current Protection
MultiMode
Input Mode Selector Switch
One Side Terminal Layout: Convenient locations for everything
Gold Plated RCA Input Connectors
Non-Fading Pre-Amp Output
Input Sensitivity: 200mV - 4V (Individual control for channels 1&2, 3&4
Frequency Response: 10 Hz - 50 kHz
Dimensions: 16-1/2" L x 8-11/16" W x 2-5/16" H
Kontakt: 53500505
Hind: 250.-
Ignar
