Bassikõlareid on 1 tükk, hind 115€
Uuena maksis 430€
Asub Tallinnas, kellel huvi siis mailiaadress on sam.white@mail.ee
Telefon 58 476 917
Tehnilised andmed,
Subwoofer Specifications
Subwoofer Size
Refers to the diameter of the subwoofer, measured in inches.
12"
Peak Power Handling
Peak power handling refers to the amount of power a speaker can handle during a brief musical burst. The RMS power range figure is a much more reliable rating for determining the speaker's power requirements. The Peak power handling specification is typically rated per speaker unless otherwise noted.
2000 watts
RMS Power Handling
The RMS power is the amount of power the speaker requires to operate safely and properly. RMS Power Handling refers to the amount of power a speaker can handle on a continuous basis. We recommend powering your speakers or subwoofer with 80%-120% of its recommended RMS rating. The RMS power handling specification is typically rated per speaker unless otherwise noted.
1000 watts
Voice Coil(s)
Dual voice coil subs have more wiring flexibility than single voice coils subs; however, single voice coil subwoofers provide easier hookup options for wiring multiple subwoofers in parallel or series. You may also run a dual voice coil (DVC) sub in parallel, series, or combination. A quad voice coil has four voice coils and is equal to two dual voice coil subwoofers as far as wiring goes.
Dual
Impedance (Per Voice Coil)
The load value (in ohms) that the speakers present to the amplifier per voice coil - the amount of resistance to the current flow. This is a key specification as subs wired in parallel or low impedances can create problems with your amplifier and potentially void all warranties. We encourage you to ask our support department prior to purchase if you do not understand which impedance level will suit your application best.
2 ohms
Frequency Response
The range of frequencies the speaker will reproduce (lowest frequency to the highest). Bigger is better, meaning the wider the range, the better. The optimal range is 20 - 20,000 Hz (which is the range of human hearing).
26 - 400 Hz
Sensitivity
An efficiency or sensitivity rating tells you how effectively a speaker converts power into sound. The higher the number, the more efficient the speaker and the louder it will play with the same input power. An efficient speaker helps you maximize your available power. Most sensitivity ratings measure the speaker's output with 1 watt of input, 1 meter from the speaker. Some speakers' sensitivity is measured with 2.83 volts of input, instead of 1 watt.
Efficiency (1w/1m) is not an accurate indicator of a subwoofer's output capability and should not be used as a comparison to other speakers or subwoofers to determine which one is "louder".
85 dB
Woofer Surround
A speakers surround is part of the suspension system. The surround protects the cone and prevents it from being displaced as it flexes out from the basket. It is usually made of a durable material like treated foam or rubber in order to withstand the strenuous job of producing bass frequencies.
Santoprene Rubber
