B207L Specification List
Myke
Auto: 9-3 SC 06" Vector
Engine designation:
Vauxhall:
Z20NET (Z = Euro4 emissions standard, 20 = 2.0 litre, N = compression ratio 9.0-9.5:1, E = injection, T = turbocharged)
Saab:
B207L
Engine installation
Front, transverse in front of axle, 10° backward inclined
Cooling system
Liquid, sealed circuit
Cylinders, number
4
No 1 cylinder location
At timing chain end
Bore (mm)
86
Stroke (mm)
86
Displacement (cc)
1998
Compression ratio
9.5 : 1
Engine, type
In line; 5 main bearings
Cylinder block/ head material
Aluminium/ aluminium
Camshaft(s), location
2 overhead (DOHC), driven by chain
Valve train
Roller rocker with hydraulic bucket tappets
Valve, arrangement
v; 4 per cylinder
Valve, adjustment
Automatic – hydraulic
Fuel system
Sequential multi point fuel injection
Ignition system
Electronic ignition map, ignition coil direct to spark plug
Fuel pump
Electric, in tank
Emission control system
3 - way cat. conv. with 2 oxygen sensors
Output
129 kW / 175 BHP at 5500 RPM
Specific power (kW/l; hp/l)
64.6; 87.6
Max. torque (Nm at 1/min)
265 kW / 195 lb ft at 2500 RPM
Specific torque (Nm/litre)
132.6
Mean effective pressure at max. power/ max. torque (Nm/litre)
1408.7/ 1667.5
Average piston speed (m/s)
15.8
Number of camshaft bearings
6 per camshaft
Lubrication:
Engine oil, capacity (l)
6
Difference between Min and Max markings on dipstick
1 litre
Oil filter type
Disposable paper cartridge, top mounted
Oil filter nut size
32mm
Oil filter nut torque setting
25 Nm / 18 lb ft
Sump drain plug torque setting
25 Nm / 18 lb ft
Minimum oil pressure at 80 C:
Crankcase
2.0 bar at 1000 RPM
Cylinder head
0.8 bar at 1000 RPM
Oil pressure warning switch activates at
0.3 bar
Oil cooler thermostat opens at
107 C (No thermostat fitted from 2008 onwards - oil cooling at all temperatures)
Coolant capacity (l)
7.5
Battery 12V, capacity (Ah)
66
Alternator 14.2V, capacity (W)
1704
Max. service interval
20,000 miles or 2 years
Emission compliance
Euro 4
OEM spark plug brand/type
NGK PFR6T-10G uuem kood siis PFR6D-10G
Electrode gap
0.9mm to 1.0mm
Spark plug torque setting
28 Nm / 21 lb ft
Firing order
1-3-4-2.
