küsimus siis kas keegi on proovinud
WOLF
VITALTECH
ATF DIII
ATM-käigukasti õli 4 käigulisele Saabile?
MärtKivimees
- Auto: Saab 9-3 TTid 2009 Vector Sportkombi
isegi dextron II on proovitud ja okey:drink:
Lihtsalt pese mitu korda läbi ja täida normipäraselt ja sõit võib jätkuda tuhandeid muretuid km
Suht selline kvaliteedi vahe viskuoosus DIN EN ISO jne nt II D
Description
Automatic transmission fluid with excellent aging
sta-
bility. Prevents the build-up of troublesome deposits.
For vehicles with proven transmission technology.
Maximum protection against wear and good friction
characteristics. Good seal compatibility. Provides
op-
timum protection against corrosion.
Properties
friction and wear reducing
excellent viscosity/temperature properties
outstanding corrosion protection
very good low-temperature properties
highest thermal stability
high chemical resistance
optimum stability to aging
Specifications and approvals:
Denison ∙ Dexron II D ∙ Ford ESP-M2C166 H ∙ Ford
Mercon ∙ GM-Dexron ∙ MAN 339 Typ V1 ∙ MAN 339
Typ Z1 ∙ Voith H55.6335.XX (G 607) ∙ ZF TE-ML 03D ∙
ZF TE-ML 04D ∙ ZF TE-ML 11A ∙ ZF TE-ML 14A ∙ ZF
TE-ML 17C
LIQUI MOLY recommends this product for
vehicles for which the following specifications
are required:
MB 236.6 ∙ ZF TE-ML 09
Technical data
Viscosity at 40 °C
45 mm²/s
ASTM D 7042-04
Viscosity at 100 °C
8,2 mm²/s
ASTM D 7042-04
Viscosity at -40 °C
<40000 mPas
DIN 51398
Viscosity index
160
DIN ISO 2909
Color / appearance
rot
Density at 15 °C
0,875 g/cm³
DIN 51757
Flash point
196 °C
DIN ISO 2592
Pour point
-42 °C
DIN ISO 3016
Oxide ash
0,22 g/100g
DIN EN ISO 6245
Sulfate ash
0,30 g/100g
DIN 51575
Description
sta-
op-
Properties
TE-ML 17C
are required:
Technical data
Viscosity at 40 °C
45 mm²/s
ASTM D 7042-04
Viscosity at 100 °C
8,2 mm²/s
ASTM D 7042-04
Viscosity at -40 °C
<40000 mPas
DIN 51398
Viscosity index
160
DIN ISO 2909
Color / appearance
rot
Density at 15 °C
0,875 g/cm³
DIN 51757
Flash point
196 °C
DIN ISO 2592
Pour point
-42 °C
DIN ISO 3016
Oxide ash
0,22 g/100g
DIN EN ISO 6245
Sulfate ash
0,30 g/100g
DIN 51575
MärtKivimees
soodsam alternatiiv Texaco Dexron III omale, mõtlen isegi seda osta sest on tunnen et oleks vaja vahetada õli.
MärtKivimees
Aga mis vahe on mineraalsel ja pool sündil ja täissündil?
See mis manual soovitab annab on mineraalõli
MärtKivimees
MärtKivimees
Mootoriõli panin castroli aga et dünaamilst käigukastiõli vahetada peab ikka üle 10ne l õli ostma korraga ning siinkohal ongi küsimus milline on hinna ja kvaliteedi suhtes parem variant. Seepärast uuringi siit ka teiste kogemusi.
MärtKivimees
AW50-40LE kast on mul
