9-5 audio küsimus
Äkki linear oli ilma? '02 aerodel on. Helikvaliteeti siiski kiita ei saa. Kui pole, siis pole, saad ise korralikud kaablid vedada ja viisakad kõlarid ühendada. Sel juhul tasub juba pigimatti ka lisada. Saad hoopis parema tulemuse kui originaalis.
E: https://www.crutchfield.com/S-cLSYmXTvo ... b-9-5.html on minuga täitsa nõus
"Depending on how your 9-5 is equipped, you'll find speakers in the center and corners of the dash, the front and rear doors, and the rear deck. None of them are terribly difficult to work with, and you'll be amazed at how much better that stock receiver can sound when it's playing through quality speakers."
