ACC ringi teha manuaalseks?
Postitatud: E Nov 09, 2020 17:15
Postitas avalon49001
Küsimus - kui keeruline oleks tonnisel ACC2 välja visata ja manuaalsed lülitid panna?
Re: ACC ringi teha manuaalseks?
Postitatud: T Nov 10, 2020 14:18
Postitas wilddog
avalon49001 kirjutas: ↑E Nov 09, 2020 17:15 Küsimus - kui keeruline oleks tonnisel ACC2 välja visata ja manuaalsed lülitid panna?
Minu mäletamist mööda on ahjud erinevad. Vähemalt NG900 AC (pliidinupud) ahi ja ACC (klahvidega) ahi on erinevad.
EDIT: Tundub, et olemasolev on kindlasti odavam parandada, kui minna manuaali peale ümberehituse teed.
infot netist:
The ACC replaces the manual controls with three electric motors. Otherwise the two systems are the same.To return the system to a manual set up will require installation of those manual controls as well as the revised manual switch panel. I am unsure about whether the recirculation flap is manual or remains electrically operated.
However, this is a lot of work to return to an inferior system when all you probably need are the new stepper motors and a new cabin air temperature sensor. The five codes will tell you exactly which parts are not working.
The ACC control unit is working (obviously or you would get only the one error code showing it isn't working). The labour to remove the electric motors and replace them with the necessary mechanical connections is going to be more than installing new motors. Plus you will have to find all the required mechanical connections as well as the instrument panel unit.
Postitatud: T Nov 10, 2020 14:25
Postitas torque
Ventika kiiruste reg. reostaat teine, ( ventika korpuse külge käib, acc versioonil konditsioneeri korpuse küljes) pistikud teised, aga kõik on teostatav.+ Trossid hoobade juhtimiseks manual puhul
Postitatud: T Nov 10, 2020 15:07
Postitas saabu14jr
Suvel tegin just manuaalse süsteemi automaatse peale ja lisaks hoobadele ja muudele asjadele peab päris palju ka juhtmestikus ümber ehitama.
Postitatud: T Nov 10, 2020 15:22
Ok tänud. Mõte tekkis sellest, et kõikidel tonnistel on minu käes acc süsteemiga mingi kala olnud. Tahaks lollikindlat süsteemi. Praegusel masinal samuti teeb siis sooja kui ise heaks arvab. Acc vigu ei näita. Paar päeva sõitsin ringi kindalaekata, et pääseks käega sammootori hoovale ligi....
Postitatud: T Nov 10, 2020 16:43
Postitas saabu14jr
Kas hakkab mingil suvalisel momendil puhuma külma?
Postitatud: T Nov 10, 2020 16:57
saabu14jr kirjutas: ↑T Nov 10, 2020 16:43 Kas hakkab mingil suvalisel momendil puhuma külma?
Jah.
Postitatud: T Nov 10, 2020 19:34
Postitas saabu14jr
avalon49001 kirjutas: ↑T Nov 10, 2020 16:57
Jah.
Katsu salongiradika lõdvikuid, siis kui sooja puhub ja siis kui hakkab külma puhuma. Või oled seda juba teinud? Kas külma hakkab puhuma siis kui termostaat avaneb ja vent tööle hakkab?
Postitatud: T Nov 10, 2020 19:45
saabu14jr kirjutas: ↑T Nov 10, 2020 19:34
Jah.
Esimest korda selline asi oli siis remondimees katsus lõdvikuid ja ütles et kuumad. Samas see olukord tekib täiesti lambist. 30-40 km sõitu ja siis järsku hakkab jahedat puhuma, ja seda mitte iga kord
