Tere
Naine otsustas proovida garaaži ukse tugevust Saabuga ja uks jäi võitjaks:wall:
Õnneks ainult klaas purunes ja kõik muu on korras. Kiire kõne teenindusse andis tarneajaks ca 5 päeva ja 1000 eeguse hinna. Küsimus - kuna tegu on Trailblazeri/GMC Envoy klooniga, siis kas keegi oskab öelda peeglite sarnasuse kohta? Chevy teenindus on tänaseks kinni ja kohapeale uurima ei õnnestu enne laupäeva minna
Kõik viited on abiks!
Tänud juba ette
Välispeegel ja uue klaasi saadavus
ise küsin, ise vastan
Hey all...
I schwacked my rt side mirror on the garage door last night and shattered the glass. Usually it just bumps the mirror back and I just have to pull it back to its normal position, however this time the planets were aligned and the glass broke.
Anyways, I couldn't find the part number online, so I called the local dealer and they gave it to me.... the RH (pass. side) is 88980571, and the LH (driver) is 88980570. Of course, since I wanted it right away I had to pay the extortion from the dealer...and it was about $50.00. :duh: I get home and plug that part number into GMPartsExpress and it's $25.00!!
But I didn't have to wait forever for it to get here
The only difference between the replacement and the original is that they do not put the little heated mirror icon on the replacements anymore but you still have the 'Objects in mirror...' clause. Just thought I would let you all know in case someone else needed the P/N. The mirror just pops on and off the bracket that is attached to the motor and you plug the heating wires into it.
Hey all...
Algselt postitas: mart284
Tere
Tänud juba ette
viking siin mail küsib 9-5 tumeneva klaasi eest 4186,- ja tava klaasi eest vist 1400.....et see 1000 on ju odav isegi:)
Uus peegel ostetud GM ( Chevy ) poest ja installitud GM(Saabi ) esinduses. Kulu 24,3 dinaari ehk ca 700 eeku
Saabi onud aint riidlesid, et mitte nende myydud peeglit paigaldan...
zupa9000cd
see küll vana teema, kuid tõstaks, kuna ei hakka uut tegema. niisiis kellelt oleks mõistlik küsida 9 7 tuuleklaasi vahetust tänapäeval. või siis ainult klaasi
Saada hunnik päringuid laiali ja vaata mis vastatakse ja kelle toodetud klaase pakutakse. Mina sain kunagi VKM-ist hoopis normaalseima pakkumise... Mõni firma vastas mu üsna täpsele kirjeldusele "tahan rohelise päiksevarjuga klaasi", et "teile pakume me odavat hiina sinise ribaga klaasi..." krt, ma ei küsinud odavaimat, vaid sellist nagu originaalis on...
zupa9000cd
autoklaasimemm rakverest otsib klaasi juba mitmendat päeva. ilmselt ei leia. kontoris küll viitasin shevile, kuid klaasitädi ütles, et tal viskaks sellisel juhul paralleelid monitori.
Kasko sul vaevalt paigaldas seda. Ikka mõni klaasitöökoda. Tuleta meelde, kes tegi ja jaga inimestele nimesid..Krt ma küll sain 2016 aasta alguses uue, ei olnud üldse probleemi. Aga see oli kasko värk ja ma ei süvenenud, kust nad selle hankisid.
Kui kevadel sai esiklaasi vahetatud, siis sai kõva hinnapäring läbi tehtud. Võitjaks osutus Glassdrive - parim hind, väga hea suhtumine ja teenindus
Täiendan, et Glassdrive-i kasuks otsustasin, sest Saint-Gobain OEM sensoriga esiklaas tuli nende kaudu parima hinnaga. Oli ka neid, kes pakkusid odavaid Hiina klaase ette, aga jah, tasub hoiduda
zupa9000cd
kui jutuks juba sensor tuli, siis ehk oskab keegi vihjeid anda, kuda kindlaks teha- on see sensoriga või ei. õigemini kas sinna kannatab üldse panna sensoriga varjanti, kuna auto juba 130000 km sõitnud, siis võib see juba mitmes klaas olla.
vaevalt sinna mingi üleliigne juhe roikkuma jääks, kui oleks anduriga versjooni asemel ilma selleta klaas.
zupa9000cd
zupa9000cd
siin foorumis on ju viikingeid ka raudselt ja mõni neist minu murele silma peale visanud. juba kolmas klaasivahetaja raiub, et tuleb tallinna reis ette võtta ja niikaua, kui bauhausis ja jyskis kolan pannakse vm-s klaas ette.
zupa9000cd
ja jänkkid küsivad täpset sevi mudelit, kui neilt tellida.
- NO FEAR
- Säärane Mulk
- Auto: päris mitu...
Mesasi see oem sensor veel on???
Minu klaas soetati 123 autoklaasist, uurisin järgi. Nädal aega oli tellimisaeg ja kohal see oligi ning pandi siinsamas ette. Selle pisikese asja jaoks ei pea nüüd küll talnasse minema.
zupa9000cd
praeguseks olen juba saanud hinnapakkumise,- seitsesada milegiga tarneaeg 3 vko, osa sellest ajast kulub raudselt tallinnast rakverepoole sõitmiseks. jyskis jääb siis käimatta ja ootan parem kodus, et õnn sülle langeks. tänud reageerimast. mul on selle imelooma kohta küsimusi veel palju, lihtsalt ei oska lauseid veel kokku panna. Aga ühe mõtlesin seda pikka juttu kirjutades välja,- nimelt arvasin,et seal võiks olla vihmaandur küljes ning nimetasin seda sensoriks ekslikult.
zupa9000cd
nopekki, palju se siis maksab tglt
- NO FEAR
- Säärane Mulk
Asi selles ongi et ma ei tea, kui palju see klaas maksab sest alati olen selle kaskoga ära vahetanud. No nii paari aasta tagant on ikk amidagi juhtunud.
Aga seda uurisin ka, et kui palju maksab tagumine klaas aga seda ei leitud ei siit ega sealt.
Mul seisab kuskil kuuris tagumine luugi klaas, probleemiks on lahti "sulanud" kinnitus. Uue sain kunagi ammu Pärnu mnt asuvast klaasipoest, mille nime ega hinda ei mäleta enam.
