Uus bensiin 95E10 Soomes
Andrus99
Auto: 99/C900/9-3
Keegi saatis huvitava lingi, tasub lugemist, kel Soome autoga asja.
http://www.e10bensiini.fi/e10_petrol/
In 2010, the petrol available in the Finnish markets contains up to 5% v/v bioethanol. Two primary motor petrols are generally available in Finland: the most common grade is the 95 octane 95E5, and the other common quality is the 98 octane 98E5.
The EU Fuel Quality Directive (FQD) and the Renewable Energy Directive (RED) imply that in the future, new petrol qualities will be introduced with ethanol concentrations higher than today. The increase of the bio-component content will help reduce carbon dioxide emissions from road vehicles.
The legislative transport biofuel obligation requires that as of January 2011, the biofuel component of petrol will need to be increased from its present level.
As of January 2011, the E10 petrol will be the principal petrol quality in Finland. Its bioethanol content may vary up to 10% v/v. Alternatively, the E10 petrol may also contain ethers and other alcohols permissible under the Fuels Quality Directive. The E10 petrol will be suitable for use in most of the current vehicle stock (see E10 compatible motors).
At least two grades of petrol will be available for the Finnish motorists as of January 2011: the 95 octane 95 E10, and the 98 octane 98 E5.
The latter corresponds with the current quality and contains up to 5% v/v ethanol. This petrol grade may also be called the “protection grade” in English (or “suojalaatu” in Finnish) because it is suitable for use in older cars as well as engines that are not compatible with the new E10 petrol.
foxer
Kütus sobib kõigile Saabidele, mis on toodetud alates 1979 :)
anthillse
Meil probleemi pole kelle auto on tehtud peale 1986 aastad.
SAAB All petrol engines since 1986 will operate satisfactorily on E10.
Huvitav kas seda 10% Etanoli oleks võimalik kuidgai paremini ära kasutada, ntx rohkem jõudu?
foxer
Mina näen sellist kirja:
Saab
E10 is cleared for use in all petrol engine Saab models starting from model year 1979.
anthillse
Saab
http://www.onlinemechanical.net/ethanol-E10.html
Ma sain info siit, et ma pole 100% kindel kas see õige info on.
No oleks sa õige koha pealt vaadanud, siis oleks kindel olnud. Miski Austraalia sait pole kõige parem infoallikas.
mart96
mingi soome lehe pealt jah vaatasin, et sobib kõigile Saabidele alates 1979 aastast, aga.... kuskilt käis jälle läbi, et see piiritus peseb paremini õli ka maha silindri seintelt ja siis saad jälle osta lisaainet ja ikka nuumata firmasid, kes toodavad neid lisaineid.
See poliitika ausalt öeldes ajab mind vihale-selle asemel, et müüa korralikku kütust, mis sobib minu autole-pean ma ostma veel mingit lisaainet:gun:
Natuke OT, aga nagu selle digileviga: möla oli kõva, et kvaliteet palju parem ja bla bla bla. Kui signaal on natuke nõrgem-nagu ise vaatan Soomes Eestit-siis vana analoogiga nägid ilusti, nüüd hüpleb ja pätkib ja seda kuuldavasti ka Eestis. Lisaks pidin tegema lisakulutuse ja ostma mingi boksi ja mis mul kvaliteedis on parem????
Aga bensiinist-kusagil soome bensukas lugesin, et b98-s on maks. 5 % seda piiritust.
anthillse
Kui õigesti mäletan siis SSil võib ka 98 sisse valada et ei pea igast lisandeid juurde muretsema.
