Uus Saab 9-5
dreamer12
Auto: Saab 9000 Aero 2,3T MY96; Saab 9-5 Aero Hirsch TTiD MY11
Uus Saab 9-5 on juba ka Trollhättanis väikest viisi kokkupanekul. Jupid tulevad küll Saksamaalt ja tegu olevat esialgse katsepartiiga, mille eesmärk on proovida kuidas oleks seeriatootmises uut 9-5 kõige otstarbekam kokku panna. Esialgu on veel peamised seadmed uue auto tegemiseks seismas Saksamaal.
Frankfurtis välja pandavad autod on aga toodetud Rüsselsheimis.
Rootsis on seeriatootmise alustamist oodata novembris. Seni toodetakse Trollhättanis näpuotsaga senist 9-5 kombit, mida augustis müüdi kogu Rootsi peale 90.
Allikas: http://www.dn.se/ekonomi/nya-saaben-byg ... n-1.950788
Seoses kohe-kohe algava Frankfurti motoshow'ga, on 9-5'st uus andmeid avalikustatud. Seda (veel) GM Media saidil.
  • All New Saab 9-5 Sedan:
    Technical Specification
    Gasoline engines
    1598 cc. 4 cylinders. Aluminum cylinder head, cast iron block. DOHC, 16-valve.
    1998 cc. 4 cylinders. Aluminum cylinder head and block. DOHC, 16-valve, VVT (inlet and exhaust). Direct injection. Balancer shafts.
    Twin-scroll turbocharger, intercooled.
    Bosch Motronic MED
    2792cc. V6. Aluminum cylinder heads and block. DOHC, 24-valve. VVT (inlet and exhaust). Twin-scroll turbocharger, intercooled. Dual-mass flywheel.
    Bosch Motronic ME9
    Diesel engine
    1956 cc. 4 cylinders. Alloy cylinder
    Common rail, direct and multiple fuel injection.
    VNT turbocharger, intercooled.
    Dual-mass flywheel. Bosch EDC
    Maintenance-free particulate filter.
    BioPower
    Fuelled by bioethanol (E85)/gasoline
    Bosch Motronic MED
    Installation
    All engines front, transversely-mounted.
    Front wheel drive.
    Saab XWD: option 2.0T, stand 2.8V6T
    Transmission
    6-speed manual gearbox,
    6-speed automatic with Saab Sentronic SWC
    Suspension
    Front: MacPherson strut/HiPerStrut
    gas/hydraulic dampers. Anti-roll bar.
    Rear: Indep, 4-link/Linked H-arm
    Coil springs. Gas/hydraulic dampers
    Anti-roll bar.
    Steering
    Rack and pinion, hydraulic assistance/VES
    Wheels, Tires
    17 x 7", 225/55
    18 x 8", 245/45
    19 x 8.5", 245/40
    Brakes (standard EU)
    Dual circuit, vacuum booster.
    ABS, TCS, MBA, EBD, CBC.
    Discs (mm, f/r):
    296 vent/292 solid (1.6T, 2.0T, 2.0TiD)
    337/315 both vent. (2.8V6T)
    Weights
    Kerb: 1575 - 2025 kg
    Max. towing weight:
    1600-2000 kg (braked)
    Capacities
    Trunk: 515 liters, VDA,
    Fuel tank: 70 liters
Rohkem infot sealt. Kinnitust leidis ka väide, et uus 9-5 on 5 meetri pikkune!!!
romza
Suurem ja raskem on see uus 9-5 tõesti, kuigi nagu kasutatakse uuemaid ja moodsamaid materjale. Muidugi auto ise ka paar senti pikem ja laiem.
Eks päriselt sisse istudes ja sõites saab nendest andmetest paremat sotti. Vana vene volga oli ka ilgelt pirakas, kuid salong oli üliväike ;)
romza
AndresV
Auto: 40/60 rida6
Algselt postitas: Skybound
...Hockey stick oleks võinud ka veel rohkem rõhutatud olla, praegune tundub kuidagi.... nuditud...
mis/kus on hockey stick? Esimeste udutulede "ümbrus" meenutab hokikepi laba, see või?
Algselt postitas: AndresV
spark
mõeldes laevadega reisijatele - kas tõesti ei saanud 9mm lühemat autot teha :conf:
SoS
Tuleb lihtsalt laevapeale minnes vastu aparelli stanget pisut "õgvendada" :P
Skybound
#284
REVEALED!
EDIT: peagi on ka nähtav video SIIT.
tõh
Auto: Saabitu
#285
Võib-olla on asi laias kaameranurgas, aga... võrratu! :head:
Autoblog'i galerii.
Olef Becker'i väga suur pildigalerii Saabi standist Frankfurdis.
See paneel näeb kuidagi porno välja. Disaini poolest tundub kuidagi viimistlemata. Häirib. et see õhus on. Või on see kusagilt lennundusest tuttav kuju/vorm?
Võiks põrandani ulatuda. Peatoed ka häirivad. aga muus osas väga vinge.
Algselt postitas: suur
http://www.blogcdn.com/www.autoblog.com ... _-(18).jpg
Paari aasta pärast lubati Koenigssssssegi mõjutusi auto juures :P
Esimest mudeliaastat ei tasu ju kunagi osta ;) Küll nad seda masinat veel paremaks teevad ;)
epsum
kui see maani ulatuks, kuhu siis keskmine inimene oma jalad paneb?
ootaks hinnainfot..
AntonG
Minule see Uus Saab nii meeldib kui ka ei meeldi.
Meeldib , et see on uus ja selline '' shining '' , ka uued tehnoloogiad, ja uus mootor ja nii edasi.
Ei meeldi et see on nii ''' paks '' praegu. Nagu kõik uuema põlvkonna autod. Meeldib minu Griffa, sest ta on selline ''kõhn''. Sirged liinid , ühesõnaga - Vector ! :)
olaviv
tõh
Auto: Saabitu
#292
Jupats
T7 sekspert
Auto: 9-5 Aero-R
#293
Mootorite järgi võib arvata, et mootorit juhib T8. I´m I right?:P
AntonG
tahaks juba Eesti teedel näha
Algselt postitas: Jupats
Ei ole... Motronicu mingid variandid on. Vaata eelpool Teageri postituses on need andmed olemas.
eston21
Auto: 9-3ss aero
#296
teager, millal uut 9-5t eestis näha saab?
Algselt postitas: eston21
Miks sa arvad, et ta teab..? ;)
Skybound
#298
9-5 on Euroopa tuuril.... 6-10. oktoober oli Nordic countries, aga Eesti sinna alla vist ei käi...
Mario153
Igast küljest:
http://www.motorauthority.com/pictures/ ... #100183882
Krt rool on küll nagu uuel Civikul:
http://l.yimg.com/dv/izp/honda_civic_co ... gwheel.jpg
Aga muidu on ikka superkena:thumb:
eston21
Auto: 9-3ss aero
#300
selge :)
