SoS kirjutas: ↑K Veebr 06, 2019 22:30Vasak on 0 ainult siis, kui sul on kaitse #35 (15A) välja võetud.
OT: kas sul järgnev funktsioon toimib?
Courtesy Headlight Feature
A delay function allows the headlights to remain on low beam for about 30 seconds after the driver’s door has been closed.
To activate this function,
• Switch off the ignition and remove the key
• Open the driver’s door
• Pull the high/low beam control stalk towards the steering wheel like you are flashing the high beam, see page 65. The low beam headlights will now come on immediately after the driver’s door has been closed (within 30 seconds) and will remain on for about 30 seconds
Jah see funktsioon toimib nii paremas kui vasakus astmes .
