Uus Saab 9-5
- dreamer12
- Auto: Saab 9000 Aero 2,3T MY96; Saab 9-5 Aero Hirsch TTiD MY11
Uus Saab 9-5 on juba ka Trollhättanis väikest viisi kokkupanekul. Jupid tulevad küll Saksamaalt ja tegu olevat esialgse katsepartiiga, mille eesmärk on proovida kuidas oleks seeriatootmises uut 9-5 kõige otstarbekam kokku panna. Esialgu on veel peamised seadmed uue auto tegemiseks seismas Saksamaal.
Frankfurtis välja pandavad autod on aga toodetud Rüsselsheimis.
Rootsis on seeriatootmise alustamist oodata novembris. Seni toodetakse Trollhättanis näpuotsaga senist 9-5 kombit, mida augustis müüdi kogu Rootsi peale 90.
Allikas: http://www.dn.se/ekonomi/nya-saaben-byg ... n-1.950788
http://www.headandlead.com - visioonid, planeeringud & ettevõtluskonsultatsioonid
Seoses kohe-kohe algava Frankfurti motoshow'ga, on 9-5'st uus andmeid avalikustatud. Seda (veel) GM Media saidil.
Rohkem infot sealt. Kinnitust leidis ka väide, et uus 9-5 on 5 meetri pikkune!!!
- All New Saab 9-5 Sedan:
Technical Specification
Gasoline engines
1598 cc. 4 cylinders. Aluminum cylinder head, cast iron block. DOHC, 16-valve.
1998 cc. 4 cylinders. Aluminum cylinder head and block. DOHC, 16-valve, VVT (inlet and exhaust). Direct injection. Balancer shafts.
Twin-scroll turbocharger, intercooled.
Bosch Motronic MED
2792cc. V6. Aluminum cylinder heads and block. DOHC, 24-valve. VVT (inlet and exhaust). Twin-scroll turbocharger, intercooled. Dual-mass flywheel.
Bosch Motronic ME9
Diesel engine
1956 cc. 4 cylinders. Alloy cylinder
Common rail, direct and multiple fuel injection.
VNT turbocharger, intercooled.
Dual-mass flywheel. Bosch EDC
Maintenance-free particulate filter.
BioPower
Fuelled by bioethanol (E85)/gasoline
Bosch Motronic MED
Installation
All engines front, transversely-mounted.
Front wheel drive.
Saab XWD: option 2.0T, stand 2.8V6T
Transmission
6-speed manual gearbox,
6-speed automatic with Saab Sentronic SWC
Suspension
Front: MacPherson strut/HiPerStrut
gas/hydraulic dampers. Anti-roll bar.
Rear: Indep, 4-link/Linked H-arm
Coil springs. Gas/hydraulic dampers
Anti-roll bar.
Steering
Rack and pinion, hydraulic assistance/VES
Wheels, Tires
17 x 7", 225/55
18 x 8", 245/45
19 x 8.5", 245/40
Brakes (standard EU)
Dual circuit, vacuum booster.
ABS, TCS, MBA, EBD, CBC.
Discs (mm, f/r):
296 vent/292 solid (1.6T, 2.0T, 2.0TiD)
337/315 both vent. (2.8V6T)
Weights
Kerb: 1575 - 2025 kg
Max. towing weight:
1600-2000 kg (braked)
Capacities
Trunk: 515 liters, VDA,
Fuel tank: 70 liters
Suurem ja raskem on see uus 9-5 tõesti, kuigi nagu kasutatakse uuemaid ja moodsamaid materjale. Muidugi auto ise ka paar senti pikem ja laiem.
Eks päriselt sisse istudes ja sõites saab nendest andmetest paremat sotti. Vana vene volga oli ka ilgelt pirakas, kuid salong oli üliväike
romza
mis/kus on hockey stick? Esimeste udutulede "ümbrus" meenutab hokikepi laba, see või?Algselt postitas: Skybound
...Hockey stick oleks võinud ka veel rohkem rõhutatud olla, praegune tundub kuidagi.... nuditud...
Algselt postitas: AndresVmis/kus on hockey stick? Esimeste udutulede "ümbrus" meenutab hokikepi laba, see või?Algselt postitas: Skybound
- SoS
- Auto: 9-5TiD, 9-5Griffin, 9-5Aero, 9000Aero, 900 T16
Tuleb lihtsalt laevapeale minnes vastu aparelli stanget pisut "õgvendada"
See paneel näeb kuidagi porno välja. Disaini poolest tundub kuidagi viimistlemata. Häirib. et see õhus on. Või on see kusagilt lennundusest tuttav kuju/vorm?
Võiks põrandani ulatuda. Peatoed ka häirivad. aga muus osas väga vinge.
Paari aasta pärast lubati Koenigssssssegi mõjutusi auto juuresAlgselt postitas: suur
http://www.blogcdn.com/www.autoblog.com ... _-(18).jpg
Esimest mudeliaastat ei tasu ju kunagi osta
Minule see Uus Saab nii meeldib kui ka ei meeldi.
Meeldib , et see on uus ja selline '' shining '' , ka uued tehnoloogiad, ja uus mootor ja nii edasi.
Ei meeldi et see on nii ''' paks '' praegu. Nagu kõik uuema põlvkonna autod. Meeldib minu Griffa, sest ta on selline ''kõhn''. Sirged liinid , ühesõnaga - Vector !
Fortes ka juttu ning pilte
Uus video: http://www.youtube.com/watch?v=QMNy8AE4D6E
Igast küljest:
http://www.motorauthority.com/pictures/ ... #100183882
Krt rool on küll nagu uuel Civikul:
http://l.yimg.com/dv/izp/honda_civic_co ... gwheel.jpg
Aga muidu on ikka superkena:thumb:
